Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Taking engine out this week. Was thinking about painting it when I put it back in. Has anyone used VHT Engine Enamel on a Harley and how does it hold up?
I did my silver heads using VHT Motorsport case paint, close match to the HD black. I primed mine with VHT engine primer & masked the fin edges with 3m fine line masking tape. Cured with a heat gun.Holding up great after 3k miles.
I used vht 550 degree gm satin black.. Great color not dull and not shinny. It held up well but I just just a big bore kit and new heads so I did all the work for nothing
