Adjusting Pushrods PITA
Old 05-14-2014 | 01:07 PM
golfblues's Avatar
golfblues
Originally Posted by AnthonyFLHX
Now being I had bike out to test ride this morning and have about 30 miles on it do I still need to wait for bleed down between cylinder pr adjustments? or will the lifters already be filled? Does this change anything in regards to number of turns etc? Thanks again.
You still have to wait for bleed down but it should be much faster. You can just add the turns from where they are or start from ground 0. I usually start from 0.
Old 05-14-2014 | 02:36 PM
djl's Avatar
djl
If you are going to readjust, collapse all pushrods and start as though you were adjusting for the first time. Always wait for bleed down between cylinders.
RomeoTango
Engine Mechanical Topics
04-26-2018 07:44 PM
lhgdale
03-15-2015 10:56 AM
95ci springer
04-05-2014 12:10 PM
NamVet69
06-11-2013 08:20 PM
klaybus
Exhaust System Topics
03-07-2011 07:12 PM
Quick Reply: Adjusting Pushrods PITA
