Dyna Motor combo HILLSIDE HELP!!
Recently bought 2005 dyna. work done by Harley dealer in Carson city NV. I want a hot rod dyna and dont know if you can make this combo work or not.
S&S 583G easy start cams
95' pistons jugs
high lift springs
SE adj pushrods
S&S air cleaner
48 mm throttle body
thunder header
no head work other than springs. what can you guys do to make this dyna spin better than it is now.
95' pistons jugs
high lift springs
SE adj pushrods
S&S air cleaner
48 mm throttle body
thunder header
95' pistons jugs
high lift springs
SE adj pushrods
S&S air cleaner
48 mm throttle body
thunder header
95' pistons jugs
high lift springs
SE adj pushrods
S&S air cleaner
48 mm throttle body
thunder header
Port the t/body(unless you want to go to an HPI unit), Zippers air filter, or our Full-Flo 3.5" unit.
That WILL git-r-done!!
Give us a call..........315-495-6650.
Scott
