Roadking cvo FLHRSE4 -08 110cui upgrade
Roadking cvo FLHRSE4 110 cui 2008 14000 miles
I have in my possession a vrod cvo 06 and during the years have have got to learn this motor , iknow revolution inside and out, can rebuild a engine and know where or what to do to boost up to get more rwhp and still dont step over the red line so on and so on.. have replaced many parts on that motor since some of them was not up to my spec. and the bike is in show condition inside and outside.
Now iam moving over to roadking cvo 110cui screamin eagle, but twincam engine is for me unknown grounds, RK is now completley stock only thing have been done is stage1(filter and exhaust)
But i have thougt of bringing that up a notch or two, on second thought i go for two)
So my q is :
i need input on what to get done my goal would be 121rwhp and 124tq i think those number would be easy to find. goal number two is past those numbers, but i would settle for goal no. 1.
in the beginning here is what i have thought of:
- porting heads with 1mm oversized valves , behive springs (expirience from revolution)
- other cams ( uncerten what cams to use)
- TB58mm ? bigger injectors?
The plan is to get a skilled Tech to do the engine for me , if there are things to replace for better parts i will have that done!
i dont want a problemchild, that bike shall be in show-condition outside and performance condition inside engine.
The cost idont care so much about.
Hopefully there is some engine guru's in here who have the expirience and can be a little teacher on what to do , what parts to replace.
So my q is :
BigMike
Screamin Eagle CVO Models
09-09-2014 09:37 PM
Iron lHorse
01-12-2014 07:57 PM
