sportster crank and rods
The engine is done. Ran it last year. Just looking to beef up the bottom end and maybe see what can be done to increase power with bottom end work. I dont know much about lower ends.
Im scared the rods are going break or the crank will spread.
Im running pump gas.
Bike turned 7400ish all last year crossing trapps in 4th gear. A lot of rpm for a stock lower end i would think.
1992 Sportster
HAMMER PERFORMANCE Bolt-on 1250 Kit with 30 Degree Reverse Dome Pistons
HAMMER PERFORMANCE Sledge Head Porting Service on XB heads
HAMMER PERFORMANCE CRUSH 600 Cams
HAMMER PERFORMANCE Billet Intake Manifold
Mikuni HSR45 Carburetor
Patriot Defender Exhaust System
bike is 10.9 to 1 compression. 9.3 to 1 corrected compression.
1.98 intake valves
stock lower end as of now.
