Rocker arm assembly support bolts
I am just curious. I'm in the middle of a cam swap and reusing the stock pushrods. I was able to lift the support and rotate the rocker arms 90 degrees so the pushrods cleared the rocker arms, but try as I might I couldn't remove the supports let alone trying to replace them when going back together. I had a hell of a time removing the cam cover too, wailing on it with a rubber mallet. I finally used a knife edged scraper in the lower right corner and tapped it in with a hammer and broke the seal. I hope to finish it today.
On my Evo FXR I put a small Jack under the engine, then remove the from Engine Mount.
You can now lower the engine using the jack, which will give you heaps of working space. I tried doing it without lowering the motor and found it to be all but impossible.
As an aside it also makes removing those damn rear rocker cover bolts easier too.
Cheers
Cheers
I have an '02 FLHT and removing that rear rocker support plate has always been a challenge but it will come out as an assembly. When I get frustrated, I call the wife out to the garage and she can remove it in the time it takes me to open another beer.
Replace the old breathers with the later version which will come with shorter bolts. Improve the breathing and future R/R of the rear rocker support plate will be a snap. Don't forget to drill the oil drain holes in the bottom of the plate to .125" while you have the support plates out.
