Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I took my cam gears apart without marking the original locations beforehand. They are stock gears. Is there a factory mark on the cams that give you the correct timing? THanks
