cam bearings
cam bearings
I am getting ready to install new andrews cams in my 2012 SG, i did not get cam bearings with the cams. i plan on replacing them, so does anyone know which is the better bearing? i hear to use the torrington, then others say use the screaming eagle bearings. any help would be appreciated in advance, thank you
Dan103
10-12-2014 12:26 PM
