DynoJet Power Vision Sportster 2012
If you have done nothing to your fuel map yet then I think it would be a safe bet that you are running way too lean. Your PV will help out a ton, if it does not already have a map with it, then you will need to download one from the DynaJet website - pick one as close as you can to your set up but don't worry if it is not a perfect match. Follow all the basic start up instructions to get that map on your bike and then start Autotuning and you will be grinning.
I have the Power vision on my 2013 and like it.
If you bought it through fuel Moto they help you with a map.
Other wise Power vision site has canned maps for many setups you can down load .
It does not take long to learn how to install a map pretty simple.
Once you have a map that is close it will take a bit more reading to figure out how to use the auto tune
