Stock muffs= lean?
Stock muffs= lean?
Not really a problem as it is a observation to hear any thoughts cause im kinda baffled (no pun). I have a 01 EGlide, 95" 510 cams, some head work,intake,V&H exhaust bla,bla. Got her set up real nice jetting wise. As described its pretty loud and being its the 6:30am ride to work vehicle I decided to have mercy on the neighbor and their little girl so I removed the V&H Ovals and put back the stock non cat muffs. Now she spits out the carb when cold and more warm up is needed to get things rollin Thought this was pretty strange myself. Also surprised the stockers are quite a bit lighter in weight than the V&H's too.
if anything, the mufflers would restrict air flow and make it run richer.. there would be no difference at idle, but mid/high range could suffer a little if its tuned to be free flowing. is it colder there this time of year? or have they switched to a different fuel mix?
spitting out of the carb is caused by timing being off, or a worn/leaking valve. neither would be caused by adding baffled mufflers, but it would cause running problems..
if it was tuned too lean with the porting and free flowing intake and exhaust, that can burn a valve causing it to run bad and spit fuel.
adding backpressure might amplify a preexisting problem.
Yes, just a lean spit just till warmed up a bit. Dont ask why LOL... but Ive swapped the stockers & V&H's back and forth a couple times and the same result happens. Temps here are pretty consistently 50 in the am. Kinda liking the quiet in my old age....now I can hear the stereo and my wife screamin at me to slow down .
OneHarleyAtATime
EVO
45
09-23-2021 07:56 AM
OneHarleyAtATime
Carburetor Related
06-11-2017 05:09 PM
