Slip Ons and Fuel Injection ? Some Clarity Please.
I have a 07 96cu in Dyna and have just fitted slip on mufflers, (the only modification) does this bike need a remap, HD Download or tune or other or will it be ok?
Millions of conflicting threads some say yes and some say no can anyone with real knowledge clarify please?
NO you don't... If you add a free flowing air cleaner it would be recommended to get a download or a richer map to make it less lean. When i bought my 07 i added Screaming Eagle slip ons. ran fine, but after a while i got a code that said the fron cylinder was lean so they fixed that....I then added a stage I air cleaner and they did the download, made a different (little more throttle response) then i bought a Power Commander III and it made it a bit more peppier...After that i added cams and a different map....
So no, if you are going to do a slip on only you do not need a download, the ECM will compensate for the slight changes in flow.
No, the ECM will compensate for the addition. I have read in several places, that if you just change exhaust and ride it for a while and then change intake, the ECM has enough movement to adjust for the changes one at a time. Harley can flash your ECM with a stage 1 flash as well. If you want peak performance, you will have to add a tuner, but just changing the exhaust, no mapping necessary.
if you change 1 or the other (exhaust or air flow) individually and NOT the other then no retune is necessary. When you change the combination of both whether 1 right now and 1 later on down the road or both now then yes you need to retune for optimal efficiency. The ECM will compensate to some extent for either but it has no possible way of compensating for both properly as the amount of air flow both in and out is outside the scope of it's "self-tuning" abilities.
Went past the local HD dealer and stopped in and talked to the mechanic he said it should be ok and pulled my spark plugs then said they look normal and everything should be fine, so that put my mind at rest, only thing is I forgot to ask him how to slow the idle speed down as it idles fast, can anyone tell me how to adjust that, or is it another trip to the dealer?
on the idle issue also..
keep your hand off the throttle.
turn the ignition on (do not start)
let the fuel pump pressure up and stop
wait 5 seconds then turn ignition off
repeat above procedure 4 more times waiting 10 seconds between ignition off and ignition on
what happens on these bikes with TPS (throttle position sensor) is the ECM will remember TP and if your hand is on the throttle when you kill the bike, the TPS is not resting at zero. Doing the above resets the TPS to zero
