Cam swap question
Cam swap question
Pulled cams out of 2004 heritage softail. Do i need to press a new type of bearing into the cam plate for the rear cam to fit properly? Looks like there is a race on the original cam that came out. It fits into the original bearing that is in the plate now. Did a dyna cam set before dont remember this issue?
Maybe time for the SE setup?
