Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
i have 87 sportster with 1200 bore.. any advice on rebuilds or gasket replacement.
What do I need for that bore.
Where can i buy the extra tools needed.
Any tricks or tips much appreciated.
Jai, welcome to HDF from the UK. Not many HDF members call in here, so post again in the Sportster section. Tell us more of what you plan on doing to your engine. Help us to help you!
