What Causes Crankshaft Runnout to Increase
Don't trust Harley.
My 103" motor blew a head gasket and in the tear down process, found that the crankshaft runnout was .019". This resulted in damage to the cams, cam plate and oil pump along with visible scuffing on the piston skirts and cylinder walls. The motor had about 30K on it and about 30 months. In the build process I didn't scimp on parts to cut costs and had them install what they recommended would go with the build from top to bottom. Now, the Service Manager at the H-D shop that did the build said it was probably due to my lack of proper maintenance so it is no fault of theirs.
I'm not inclined to think that the crankshaft runout occurs over time but rather is a manufacturing problem.
Can someone give me some insight on this?
@dirty.bohagen The post your replied to is about 14 years old. I see that you are new to the forum; it is always a good idea to check the date of the last post in a thread; it could be 14 years old
Details on the parts are: Crank was a JIMS. The build was a 103 stage V by Patriot Harley of Fairfax, VA. The big bore package is still advertised on their web page.
The Service Manager told me that dyno tuning it up to 108h/121t was one of the things that probably caused it too.
My riding style was more at highway speeds touring. Not a bar hopper, no wheelies or burnouts. Oil changes were always at about the 3K mile point with filter change as well.
I don't know if improving the output by the dyno tune really is a factor in this. Patriot did an initial dyno tune then after the 1000 mile break in, they did another tune and it produced 96h/101t.
Bowhunter61
02-02-2017 06:07 AM
