Fuzz. Mixed up rocker arm support plates. Does it matter?
Hey,
I'm installing a 103 kit on my '07 Fat Boy. Following the great threads and savvy advise of HDF members, I have been carefully removing the parts and fastners, bagging and labeling everything. Then, before I realized my error, I had both rocker arm support plates sitting next to each other on my table, unmarked and unbagged. They look exactly the same. Shi!. I tried to remember which I put on the table first and its location, but just tricked myself into remembering which was which. Really, I hadn't started the booze juice until after this oversight. Does it matter if they don't go back to their original cylinder? Even if it doesn't matter, is there a way to figure out which goes where? There are different numbers stamped onto each one, but I can find any information online which tells me what the numbers mean.
As always, I appreciate your help.
I'm assuming the rocker arms are still intact. Correct?
It would be nice to reinstall to the same head as they were removed from since the rocker arms are worn-in to their respective pushrods and valves, but it's probably not the end of the world if otherwise.
Then again, you may be replacing the pushrods as part of your build so you can disregard that half of the equation if that's the case.
The only thing left then is the rocker arm to valve stem wear pattern. Although good practice would dictate keeping those the same, it's not a catastrophic F-up if they get mixed up.
skjskmata
11-10-2011 11:52 PM
