Lifter orientation
Old 08-13-2011 | 08:40 PM
hillclimb's Avatar
hillclimb
6th Gear
Default Lifter orientation
Assembling a twin cam. The manual is not specific regarding the orientation of the lifters to the oil holes. Some of the after market cams direct you to align the holes in the lifters with the holes in the block.
Have not found anything that states specifically except to install them how you removed them. I didn't remove them. Any help?
Old 08-13-2011 | 09:32 PM
BLKBAGGER's Avatar
BLKBAGGER
It doesn't matter when installing new lifters. They say to install old one like they came out because of the wear pattern. Are the lifters new?
Old 08-13-2011 | 10:35 PM
hillclimb's Avatar
hillclimb
6th Gear
Default Hillclimb
Thanks. Both cams and lifters have less than 100 miles on them so there shouldn't be much of a wear pattern. Might try to line up the holes just for grins. From what I have read it can't hurt anything.
Old 08-14-2011 | 01:32 AM
BLKBAGGER's Avatar
BLKBAGGER
You should be fine either way.
willeb3
Engine Mechanical Topics
12-20-2014 11:17 PM
californiafatbob2013
08-24-2014 05:36 PM
jammerx
02-13-2014 11:52 PM
bigdog1949
Exhaust System Topics
10-19-2013 07:29 AM
sober1
07-28-2013 06:24 PM
