Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I'm thinking of getting Samson True Duals for my '08 Heritage but I'm worried about a couple of things. Will I have to re-program the ignition? Will the new pipes fit around my passenger floorboards?
For TD exhaust - best to have the bike "flashed" to allow for this mod, unless you already have tuner (self-adjust). If you order correct system for bike - FB's shouldn't be a problem, but you can always contact Samson to verify. Good luck w/the install!
Samson's true dual exhaust does fit with some passenger floorboards. Please visit our web site to see all the options available for you at www.SamsonUSA.com.
Thank you,
JR
