Is it right price? shovelhead engine overhaul
I've overhauled the engine of Harley Davidson 82' FXWG.
Total cost is $4,028.19, but I don't know it is right price or not.
Please tell me your opinion.
LABOR VALVE JOB CHANGE VALVE GUIDE,VALVE GUIDE
SIZING,
SEAT CUT ,LAPPING..
8 50.00 400.00
Parts VALVE ROWE INTAKE BLACK 2 38.00 76.00
Parts VALVE ROWE EXHAUST BLACK 2 38.00 76.00
Parts VALVE GUIDE 12.5 4.00 50.00
Parts VALVE SPRING KIT 1 100.00 100.00
LABOR BORE CYLINDER 1.5 60.00 90.00
LABOR ENGINE OH INCLUDES SANDBLAST AND PAINT. 20 60.00 1,200.00
LABOR FLYWHEELS BALANCE INCLUDES PARTS
BEARINGS/THRUST WASHERS
5 60.00 300.00
Parts LEFT CRANKCASE BEARING 1 23.50 23.50
Parts SHIFTER ROD 2 32.99 65.98
Parts TRANS DUO SEAL 1 9.99 9.99
Parts J CAM 1 102.06 102.06
Parts BREAKER CLIP 1 15.99 15.99
Parts FALSHER SOLID STATE 1 7.36 7.36
Parts LIGHT SWITCH 1 8.99 8.99
Parts STARTER SWITCH 1 6.99 6.99
Parts BULLET LIGHT 2 19.98 39.96
Parts TRANS SEAL 1 1.99 1.99
Parts MAIN SHAFT SEAL 1 6.99 6.99
Parts BASE WASHER 1 9.21 9.21
Parts BASE STUDS 1 18.61 18.61
Parts S&S BREATHER GEAR 1 55.40 55.40
Parts HEAD BOLT KIT 1 22.64 22.64
Parts INTAKE CLAMPS 1 9.99 9.99
Parts S&S PUMP 1 219.82 219.82
Parts ADVANCE UNIT 1 39.99 39.99
Parts CHARGING SYSTEM 1 120.00 120.00
Parts BATTERY 1 80.00 80.00
Parts SHIFTER LEVER 1 24.90 24.90
Parts MC PISTIN .030" 1 96.50 96.50
Parts BASE NUT 1 12.49 12.49
Parts THROTTLE CABLE 1 7.97 7.97
Parts JAMES GASKET KIT 1 44.90 44.90
Parts INNER SHIFTER LEVER 1 15.97 15.97
Parts SHIFTER SPRING 1 8.00 8.00
HANDLING HANDLING PARTS 1 135.00 135.00
LABOR SPRINGER REPAIR 1.5 90.00 135.00
LABOR WIRING 5 60.00 300.00
LABOR TRANSMISSION TOP OH AND PAINT 1.5 60.00 90.00
SIZING,
SEAT CUT ,LAPPING..
8 50.00 400.00
5 60.00 300.00
Moog Player
01-26-2010 06:07 PM
drahc
General Topics/Tech Tips
12-03-2008 06:38 AM
