No spark to rear cylinder
I have 1200 XLC (2001). I have not rode much this past summer, but I recently pulled it out to go for a spin. It rode okay, but I did notice it was missing at idle. I parked it and today I went to start it and it was missing really bad. I checked the spark and I am getting no spark or a weak/intermittent spark at the rear cylinder. I changed both plug wires and the problem persists. I checked the spark at the coil and the front is sparking, but the rear is not. Is it unusual for a coil to go bad and only one side sparks? Could the problem be in the ignition module?
I have a HD repair manual for this bike, but it does not cover a single cylinder spark problem. In fact, the test for the coil is whether or not it sparks. Fact is, it is sparking, just one cylinder, though. This Sportser uses a dual spark ignition in that it sparks simultaneously for both cylinder. Any advice to test components would be greatly appreciated.
Here is what I have done so far:
*Checked resistance on primary and secondary coil. They are within normal limits, but on the low side.
* Cleaned and re-gapped plugs (they are fairly new with less than 500 miles on them).
*Checked power to the coil with ignition on. Primary supply is fine.
* Replaced both plug wires.
Any help is greatly appreciated. Thanks.
