evo to shovel head
Old 10-12-2010 | 11:32 AM
MikeCarenter's Avatar
MikeCarenter
Stage I
Default evo to shovel head
is it possible to put a mid 90s 80 inch evo motor into a mid 70s 4 speed shovel head for replacement motor
Just that the motor is available and shovel motor is hashed
Old 10-12-2010 | 03:39 PM
48pan's Avatar
48pan
Bolt pattern is the same but evo motors are taller than shovels. You'll run into some frame issue but if you have access to welding tools it can be done.
Old 10-12-2010 | 03:48 PM
hobobiker's Avatar
hobobiker
I agree with 48Pan, but be careful not to just start grinding on the frame for clearancing. I've seen more than a couple frames crack/break when someone thought this would be an easy "grind off / bolt on" kind of swap...
anwilson
03-02-2012 12:28 PM
Zenki7
Ironhead
08-12-2010 12:34 AM
Rebel78
Exhaust System Topics
01-19-2009 06:44 AM
festiva 1
07-17-2007 08:26 AM
Eyeball Kid
Custom Models
07-15-2007 11:14 AM
Quick Reply: evo to shovel head
