Spark Plug Anti-Seize
I use the Nickel based, it has a heat rating good to 2500 degrees, I doubt that that temp is ever exceeded,
http://www.shoplet.com/Loctite-Nicke...SEPTLS44251102
The copper is rated to 1800 degrees (you still probably not reach that temp either).
http://www.grainger.com/Grainger/Ant...icants-_-3ZDV6
BUT, I only use the Nickel because that is what I can get free.
