Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
No you can reuse them, however, they are less than 10 dollars. After you install the new pipes, every so often (monthly or so) check the four exhaust nuts. I found mine came a little loose, causing a small exhaust leak.
