Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I just installed a set of cams in my Road King. And know after completing the install, I don't have any oil pressure. No oil in the oil filter, so I filled it with oil and reinstalled. Nothing. Tried pooring oil into the lifter blocks and still nothing. Oil tank is full, but the pump won't pump. I talked to a tech at a local shop and he thinks the bike is hydrolocked. Any body have a way to get the air out of the pump? Or any idea as to what is going. Thanks in advance!
Thanks for the advise guys. Took everything apart, and I made mistake installing the oil pump. Put the wavey in out of order. Reinstalled everything and re-aligned the pump. Built pressure within 3 seconds this time around. Thanks for the help!
