Tried NGK plugs - your favorite?
Old 09-19-2008 | 08:01 AM
mjunk1's Avatar
mjunk1
Default Tried NGK plugs - your favorite?
When I first got my bike I picked up some NGK Iridium plugs as the ones in it were fouled (90 EVO). I put in the NGKs and it ran great. Had a friend who is a long-time HD owner say I was blowing it and needed to put in HD plugs. After a month or so I stopped by the dealer and picked up a set. Swapped them out and have to say, I was totally unimpressed. Didn't run any cooler, was harder to start, and performance in hard acceleration seemed a little duller. Put the NGKs back in and it perked back up. Now I'm trying to get my friend to give them a try.
Anyone else running these with the same results? Any other plugs you love?
Old 09-19-2008 | 09:54 AM
ngoti8tor's Avatar
ngoti8tor
For the money, I'd stick with the NGK Iridium plugs. A lot of guys will say "why waste your money?", but I figure $20 or so, over how many miles, amounts to peanuts per 1000 miles. It's a Harley, so why cheap-out on it?
Old 09-19-2008 | 02:50 PM
Dr.Hess's Avatar
Dr.Hess
I use NGK Iridiums in my Esprit Turbo. They are said to fire better in extreme conditions like on a boosted motor or one with high compressoin. I fortunately only need 4 and they last a while.
I generally use NGK plugs in everything, but I tend to stick with Genuine HD for the bikes. I'm not sure whats in them now. Probably NGK in one and HD in the other.
Old 09-20-2008 | 06:16 PM
bigoscycles's Avatar
bigoscycles
We use NGK Iridium in everything unless the customer wants something different. Never had any complaints.
Old 09-20-2008 | 06:50 PM
Eyeball Kid's Avatar
Eyeball Kid
I've two (2) Shovels, and run Cheapie Champions in both. $1.29 and there is not a better plug I have tried, and I have tried many.
Old 09-25-2008 | 07:41 PM
bagga's Avatar
bagga
$1.29 champions for me too. $20.00 for 2 plugs? no thanks i'll stick with the champions
Old 09-26-2008 | 06:39 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Default Ngk
Did not know that this was a secret.
We have sold NOTHING but NGK plugs for almost 20 years now.
Iridiums, standard, many heat ranges, for all models (Harley) and BR9ES's for the snowmobile crowd.
Old 09-27-2008 | 05:53 PM
jandlcars's Avatar
jandlcars
From: NOMAD Milton FL Now Originaly From San Rafael CA
After 22000 on 06 Dyna with HD plugs changed once
I am now using NKG Iridium better start up less twist on throttle I ride daily same rout
Now for Gas mileage check been averaging 41.2 will report soon
Old 09-28-2008 | 06:24 PM
jandlcars's Avatar
jandlcars
took first gas check 178.7mi divided by 3.85 = 46.3
i will do more checks
When i purchased it i was told 50+ mpg normal and 35 mpg if ridden like i stole it
Have checked mileage since new so i have a good record not just a one time thing
Old 09-28-2008 | 06:37 PM
jarhead45's Avatar
jarhead45
what is the plug number / part number on those NGK's..... gotta know what to ask for at the auto store dont I .....
Quick Reply: Tried NGK plugs - your favorite?
