Different Types Of Spark Plugs
Old 02-25-2006, 11:28 AM
HDF Tech's Avatar
HDF Tech
HDF Tech is offline
Default Different Types Of Spark Plugs
This topic has surfaced many times here and there are a few things to be considered before a switch is made..
I would stick to the stock plugs recommended for your motor or you will defeat the purpose of the ION sensing in the ignition system that detects and deals with engine knock. It uses the principle of resistance in the secondary ignition circuit and varying that resistance can knock the system out. The only benefit with plugs like platinum plugs is that they last longer. Different plugs would make literally no difference in the running of the engine. The basic principle here is to light off the mixture and unless you had worn plugs in there with excessive gap, there would be little if any difference in a switch to a different plug. One exception here is a different heat range of the same plug which would not cause a problem.
Very high performance engines running higher than normal compression ratios is the other exception here.
ION sensing explained... HERE
TWIN CAM 96
03-07-2012 01:15 PM
exemexer
11-19-2011 08:31 AM
CT-Bagger
08-17-2011 11:30 AM
jd_underdog
02-26-2006 03:24 AM
WarriorHD
14
01-07-2006 12:31 AM
Quick Reply: Different Types Of Spark Plugs
