90 Sportster Rear Sprocket
Old 10-17-2024 | 10:05 PM
Vza's Avatar
Vza
Default 90 Sportster Rear Sprocket
Hey All, I'm cleaning up the rear sprocket...chrome flaking off. Going to sand it just spray chrome paint. When I removed it I noticed it was pretty pristine on the inside. Would it be possible to install it backwards. Outside pitted chrome to the inside. Or is there some kind of mating between chain and sprocket. Bike has 17000 MLS.
Old Yesterday | 07:41 AM
bustert's Avatar
bustert
i would not recommend that
look closely at the pulley profile, one side is a taper and the other side is a staked plate. if you run against the staked plate and it fails, the belt can do some pretty dangerous stuff.
you can fine media blast the pulley and use some krylon fusion paint.
Old Yesterday | 08:28 AM
Vza's Avatar
Vza
Its chain driven but I have a feeling its not advisable either way. V
Old Today | 09:24 AM
bustert's Avatar
bustert
must be a conversion
a sprocket can be reversed if it is not stepped to fit one way, the only concern is if the teeth have a curvature to them. if they are consistent and not needle sharp probably will be alright.
Vza
Engine Mechanical Topics
08-18-2024 01:29 AM
bighosschato
02-18-2014 03:20 AM
Custom93XL
07-08-2012 04:06 PM
Ultra Custom
03-30-2009 05:59 PM
Scarletthehog
Ironhead
17
04-19-2008 07:27 AM
Quick Reply: 90 Sportster Rear Sprocket
