98 evo randomly loses power
Old Yesterday | 08:16 PM
ilostaustin's Avatar
ilostaustin
Stage III
Default 98 evo randomly loses power
Hi I have a 1998 evo softail and need help figuring out why when I'm riding, the bike will randomly lose power then a pop from exhaust. Sometimes it will die while riding other times it won't. Sometimes it will die 10 feet from my house when leaving. It then starts back up just fine. the coil and plugs are good. Has drag pipes. Thanks.
Old Today | 12:19 PM
nevil's Avatar
nevil
Received 1,039 Likes on 776 Posts
Battery cable connections would be a good place to look. Both ends, including the ground.
Maybe clogged fuel filter or petcock filter, or the carb needs cleaning/rebuild.
Old Today | 01:04 PM
pgreer's Avatar
pgreer
Received 1,657 Likes on 1,062 Posts
I'd check the ignition inside the round cover on the cam cover. Look for discoloration or something oozing off the pickup. Then check the petcock for fuel flow. I believe that model came with a vacuum controlled fuel flow petcock and they will fail over time.
Paul
Old Today | 01:51 PM
im's Avatar
im
Review inside of tank for possible tank liner release or random garbage.
The garbage blocks fuel flow, bike cuts off and trash moves away...then repeats.
Ward1963
01-18-2023 01:47 PM
fastsoup
Audio Systems
03-28-2022 08:00 PM
texashillcountry
EVO
70
10-13-2019 10:48 PM
salvatorejrm
Exhaust System Topics
12-14-2015 09:19 AM
Nautilus
09-16-2009 11:13 AM
Quick Reply: 98 evo randomly loses power
