2007 road glide starts and shuts off immediately
2007 street glide with road glide conversion kit
96 CI motor fuel injected.
What's up. Hoping to get some help on a running issue. I just got a 2007 street glide with a road glide conversion and having issues with keeping it running. It'll start and die immediately. Sometimes it'll run for 5 to 10 seconds and shut off. Before it shuts off it idles high and low like a misfire/fuel starvation if it does run for 5 seconds. It did run before the check valve replacement and taking off the front fairing.
AIl codes will erase except for PO118 PN32515-07.
I assume the excess of codes could also be a wiring short? Making me think something in the fairing isn't pulled in?
I got the bike last week, had a leaking check valve so replaced that and it doesn't stay running now. No leaks in fuel assembly and everything is hooked up properly 100%. I've been thru the leaking lines and leaky FPR in the tank on a previous bike so I know this is hooked up correct.
Cleaned 02 sensors since they were black, cleaned spark plugs since they were black and fresh gas in tank.
While waiting on the check valve, I took the cowling off the front fairing and not sure if I disconnected something or if it even matters with front fairing on or off. I only disconnected the lights.
Its throwing a lot of codes for heat sensor, O2 sensors and more in diag mode. I cleaned the o2 sensors, checked for spark and there is spark.
Could an o ring on the fuel line connecting the line to the check valve be an issue? It looks dry rotted........
Also not sure where the small yellow and white wires go that are attached from the headlight. ( I'll figure out in time, but wanted some insight if someone has any because I have my work cut out for me in this bike)
Thank you for any input.
I attached pictures of the codes so maybe someone can help if they had similar issues.
Temp sensor replaced yesterday - Did not change anything other than I have 0 codes now
As the others say next thing is fuel pressure. One thing you can do is listen to the fuel pump. It should run for about 4 seconds at key/ignition on. You should also hear it run for a few seconds after the motor quits. If not it may be flakey system relay.. IIRC they will throw a code.
Check for codes in TSSM.. Maybe the security light is not functioning.
It could also be the fuel line going to the injectors. The ***** in the quick connect can wear into the groove on the line and cut fuel flow.. You can try pushing up on the connection to see if it helps.
