push rod adjustment and heat.
Old 09-17-2024, 06:28 PM
paud's Avatar
paud
paud is offline
Because it can't collapse as far so it's easier to recover. Less oil in the upper chamber used. A little less fluid compression due to less fluid in the lower chamber.
Thank you. That all makes sense to me.
and now for the next inquiry. Is the following scenario possible or probable?: Harley says to adjust their pushrods to 2.5 turns. That would put the preload on the lifter at .104 preload. (24 TPI). Would it be wrong to assume that when the engine gets hot and everything expands that the ability of the oil pump to move the proper amount of oil into the lifter at slower rpms, is not enough to prevent the push rod from bottoming out, or coming close to bottom?
Old 09-17-2024, 08:45 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is offline
Received 5,957 Likes on 4,033 Posts
Actually in the cases of the pushrod centered to 0.140 or more, the pushrod typically does not bottom out the lifter. It's probably not until the pushrod is adjusted until about 0.010" from bottomed that it actually can bottom out.. When you hear lifter noise it's not the lifter bottoming out but the valve dropping hard on the valve seat. Going deeper simply helps with recovery.
It's probably more appropriate to say, " Because it doesn't collapse as far so it's easier to recover."
Some of that may be due to preload on the little spring inside the lifter is a little more and a little deeper may also bleed a little less.
Old Yesterday, 05:44 AM
jake24lt's Avatar
jake24lt
jake24lt is offline
Received 1,535 Likes on 827 Posts
Originally Posted by jbarr1
Rocker lockers —-
Its an M8, no rocker lockers
Old Yesterday, 12:45 PM
paud's Avatar
paud
paud is offline
I do like your responses. They make me understand more, think more, and ask more questions. My next one is, if the valve is dropping hard on the valve seat, would there be a proper adjustment to help quiet that down?
Old Yesterday, 02:20 PM
Max Headflow
Generally it boils down to better lifters with less bleed. One thing to note on a M8 is that the valve stem protrusion on both one side (intake or exhaust) needs to be the same for the 2 valves. If not then one valve will hit the seat harder. One thing you can do is buy rockers that have an adjustment to balance valve lift.. HD makes some.. I've not used them but a few here say it's helped.
My M8 is stage 2 with stock mufflers.. It will likely stay that way..
Old Yesterday, 03:06 PM
Scrmnvtwins's Avatar
Scrmnvtwins
Scrmnvtwins is offline
Could simply be valves closing on seats......... Changing the cam profile usually results in extra lift and longer duration which by definition deceases ramp time closed to open and open to closed which can result in valve train noise. I know on every new bike I have added a performance cam to the 1st thing I noticed was new valve train noises.
Kinda old school but a piece of wood rod radiused at both ends makes a great stethoscope. Go cut the end off your ol'lady's wooden broom handle and sand a radius on the cut end. Take that to the engine and place the factory smooth edge on your ear while you move the other end around on the engine. You will hear everything internal to that engine and you will kow exactly where the noise is coming form.
soarguy
Engine Mechanical Topics
05-08-2023 04:21 PM
Cruisineasy1
01-14-2014 10:30 PM
rm4040
03-28-2011 04:44 PM
HemiGlide69
10-31-2010 07:27 PM
RE AND CHERYL
Exhaust System Topics
05-13-2009 02:58 PM
Quick Reply: push rod adjustment and heat.
