Stroke or not to stroke, that is the question.
Hello all, I’m putting together a rider Shovelhead, nothing crazy but will be ridden fairly hard. I want to build a solid engine . I have the opportunity to get a 4-1/2 stroke s&s crank, I don’t want to bore the cases to 3-5/8 so I will be running 80” barrels. I’m debating between the 4-1/2 stroker or a 80” crank. Would love to hear from people with real life experience with these engine combo’s. What are people’s thoughts? Thanks
the shovels have crappy heads. i would drop some coins there first and then decide what to do next. can they be made to run, ?, why sure.
also of note, the stock tranny is a slug so andrews 1 & 3 ratio change is a big boost. my 74 fxe with manual foot would smoke a few mc's that normally would leave it behind.
as far as boring the case, no biggie. also of note, the more you push it, the more reliability goes down.
Pi-UNIT
12-28-2009 07:56 AM
