Metallic noise at low RPM
Hello,
First, apologice for my english.
Im a CVO ultra classic 110SE 2007 owner with 31.000Miles.
Last day going back to home a metallic noise started in my engine. It sounds more at low/lowmid RPM, when engine its running at 2000rpm it dissapears or stabilize. I tried to locate it as broken support but didn't found anything. I suspect it sounds in the right level, oils are ok.
On video air filter is dismounted to check valve screws.
Any idea where to start checking? i have some knowledge and tools but open random parts its crazy for me.
Regards.
Regards.
Juan.
You need a two ear mechanic's stethoscope with a prob on the end to isolate the noise. Sounds travel all around and using your had or a screw driver on one ear doesn't do very well.
Once you here the noise the loudest at, look here what's under that area
Wear often happens on the tension shoes running on the chains that drive the cam shafts. Caution.. just guessing here.
https://partsfinder.onlinemicrofiche...avidsonmc/2007
Juan.
good idea use estheteoscope, but im a little "scared" for start engine if that could make bigger problem (A metallic part finally broke and generate a big issue) Oil pressure its ok, may be this its a good signal. Talking with a friend he points to a chain tensor "sometimes when it broken generate similar chirp and stop when high rpm strengh the chain).
Open oil pump case its only a few screws (exhaust and cover) no?
porkster (01-18-2024)
Thanks for the response.
On my Softail TCb, with OEM exhaust, all I needed to do was loosen the exhaust shields to gain access to the cam case cover bolts.
I had a little trouble popping cover off. I had replaced the faux timer cover years back. I drilled a hole in the center of the little old cover and put it on temporarily and used my sliding hammer to pull cover.
If it's the tensioners, that style has a pin looking part that breaks through center of delrin shoe.
Look through this thread for what wear looks like and can happen to that style of tensioner.
https://www.hdforums.com/forum/engin...ing-chain.html
The cam case doesn't have a lower drain since at bottom is where oil pump return picks up the oil from crank case side.
The oil level is up to the main bearing of the crank case in the cam gallery side.
So, yes, about a couple cups of oil will pour out. After checking mine and starting it up to get oil normal, it dropped oil level on the dip sick about a 1/4" (6.5 MM)
Over here is US, we get a different blend of fuel in the winter in Northern States.
But, remember, I was guessing what could cause noise. I actually didn't hear much noise.
I would think bad fuel would cause a ping spark knock running down the road under load.
