Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hello.
I want to install on twin cam 88 a new breather assembly (17025-03A). Is there supposed to be a gasket between the breather assembly and the rocker arm? Or if the part is new, the gasket is not inserted?
Thanks.
