PITA Rocker Box Allen Bolts
So, getting ready to get in to the rocker boxes on my 14 SGS for the first time to do some things, and I come across these little suckers. Left side rear jug. Somebody put them in while this motor was still in the frame, and I can get them out with a little work, but how am I going to torque these to spec? 3/8" drive dog bone with 1/4" box end and a stub off of a 1/4" allen wrench? That's all I got. If so, I guess I need to get some dog bone torque adapters huh........ Anyone else got a better way/plan??
The following 2 users liked this post by roussfam:
eighteight (04-27-2023),
rol427 (04-27-2023)
They sell a special wrench for exactly that I've seen on Amazon and a couple other sites and I've also seen guys on here cut an allen wrench down to fit using a wrench. Like said above if you get either I would think you'll be fine torquing by hand for the torque spec isn't that high. I don't have a manual in front of me for the exact torque spec so check your service manual first.
Ride safe!!
Ride safe!!
1 2 many (05-02-2023)
https://www.amazon.com/V-Twin-16-652...s%2C101&sr=8-3
Ride safe!!
Ride safe!!
The following 3 users liked this post by PureHybrid:
MotoJockey (05-03-2023)
You can cut off a 1/4 inch allen wrench to get a stub that sticks up, then use a offset double box ends and a fish scale to torque the bolt.
Fish scale LBs will be TQ spec x12 / center to center distance on the wrench.
Say the spec is 10 ft-lb and the wrench is 6 inches. 10x12/6 = 20 lb.
I'm with pure-hybrid, ARP bolts.
Yup, 12 pt. ARP bolts....... next time, which isn't in the too distant future when I get back from this next trip. It's really close to time for an upper end refresh/upgrade.
I ended up doing a few practice torques with the torque wrench vs the Snap-On ratcheting 1/4" hex allen wrench with the cut off allen stub in it. Use that wrench on all 12 bolts to make them all the same. I feel pretty good with that and after all, it's only the rocker cover. I'm sure it will be fine until rebuild time. Might need to buy a fish scale though, lol.......
