Have a look at this cylinder scoring
Old 09-24-2022 | 12:46 PM
smitty901's Avatar
smitty901
55K that is some serious wear. Was it ever a flood bike?
Old 09-24-2022 | 01:50 PM
brownie4412's Avatar
brownie4412
not to my knowledge. It was bought new in 2015 or 2016.
Old 09-24-2022 | 02:15 PM
pgreer's Avatar
pgreer
The cylinders need to be straight and round for rings to seal properly, and hold up over time. And by the time you had cylinder anywhere nearly round and straight, the current pistons would be lose enough that they would knock. It's simply not worth the effort. Bore the cylinders and replace the pistons and rings. And, with that many miles, the heads need to be reworked to include a valve job and stem seals.
Depending no what has been done previously, and when, it is likely time to open the cam chest and upgrade components like cam chain tensioner shoes and lifters as well as anything else that is worn beyond specs. Oil pump?
Paul
djl (09-24-2022)
Old 09-24-2022 | 04:42 PM
Max Headflow's Avatar
Max Headflow
They need boring but from the looks, they may need replacing.. Looks like a 110 motor that might have already been bored over. Not much material there..
The following 2 users liked this post by Max Headflow:
pgreer (09-24-2022), TwiZted Biker (09-24-2022)
MiniWolf
The General Motorcycle Forum
15
01-31-2013 02:46 PM
chevypilot
Motorcycles For Sale
05-14-2012 09:00 PM
BrassHOLE
08-16-2011 08:41 AM
Quick Reply: Have a look at this cylinder scoring
