Tuning Road King - is this a massive problem?
Will it break the bike!?
The 2009 Road King came with a 103 derby cover but I have no way to tell it it’s a 103 or 96. I’m about to put a tuner on it with canned tune. Can I try 103 tunes without damaging the motor?
Id assume if I try 103 or 96 and if runs like crap, then it’s the other motor.
What do you think?
What do you think?
What canned map? The canned map shouldn't damage the motor. If the tuner is the FP3/4 a few auto tune sessions should bring the tune into a reasonable configuration.
You could also run a compression test which will answer the 103 or 96 question.
rnewkumet (08-09-2022)
What tuner? What canned map? The canned map shouldn't damage the motor. If the tuner has an auto tune feature and the tune is off, a few auto tune sessions should bring the tune into a reasonable configuration.
If the OP went bigger bore, the displacement could be 103 or even 107. We keep guessing but the only way to know the displacement for sure is to pull a head and measure bore and stroke.
EDIT: Thanksk for the correction from rigidthumper; had to edit the VIN comment per his correction. I will stick with the rest of the post.
I would go by Rigidthumper's statement, he's one of the most accurate sources of information here
Flash the 103 tune then run an auto tune session, if the VE numbers drop dramatically then maybe it's a 96, but not a real accurate method any way, sometimes displacement is bumped to compensate for maxing out the VE's
bottom line is give the engine what it wants to run, isn't that the real purpose of tuning
rigidthumper (08-10-2022)
