Shut off valve in oil feed line
Anyone try running a shut off valve in the oil feed line off tank of a Softail to keep it from draining when it sits? I never really had this issue til going to a 3 stage pump. Now it drains rather quickly. Of course it returns rather quickly too with the improved scavenging but I'd rather it didn't drain in the first place.
Harley1004 (04-20-2022)
The following 2 users liked this post by eighteight:
Harley1004 (04-20-2022),
IronAss (04-19-2022)
I remember someone saying the wavy washer in the stock pump keeps it from draining. R&R said they're on drugs tho and it has nothing to do with it. Just depends on where the gerators stop.
I have a gearotor pump on my bottom breathing Evo with gravity fed oil tank. I clamp the feed line if gonna sit for a bit. My problem is it also kicks oil out the breather instead of just returning. If it just returned to tank. Don't know if I would bother.
I have fielded many calls from customers about low oil and then over filled after they start. Always remember to check oil at running temp.
Does pinching them off eventually cause the hose to weaken there? I would think so and why I thought of a shut off valve.
The two ends of the hard lines almost touch too. Not leaving much hose to pinch. But either way I'd have to do something about that so.
Received 5,393 Likes
Uncle Larry (04-20-2022)
