S&S piston marking
S&S piston marking
Purchased some .010 pistons for my 124 and it seems both are marked with an F indicating front piston. That being said the part numbers are 920-0020 (front) And 920-0021(rear)
I’ve done several of these and never seen an F on the rear piston. As as seen in the STD piston a clear F and R
just to be clear if I were to use the F as the front of the piston id be be running a boxer style engine.
SS says no worries, I say something it’s t quite legit
thanks
thanks
