Replace everything it not ??
Old 01-08-2022 | 12:33 PM
Kwikwilson007's Avatar
Kwikwilson007
Originally Posted by fat00boy
Why do the scratches near the wrist pin in the second pic have a curve to them when the piston travels in a straight line? Dirty assembly?
I think what you’re seeing is probably a reflection.. some of these pictures are up really close and the light plays tricks on the camera… they actually look worse in these pictures
Old 01-08-2022 | 12:35 PM
Kwikwilson007
Didn't know you could use 4 inch bore on 96 cases. I thought the largest you could go was 3 13/16"
they have kits from s&s and I believe HD may have one also .. these are s&s cylinders and pistons..
Old 01-10-2022 | 02:07 PM
pgreer's Avatar
pgreer
Yeah, unless you have torque plates, micrometers and bore gauges (not telescoping) you would be better off taking them to a machine shop that specializes in this type of work.
Looks like some of scratches mae be from assembly, like from the ring compressor. And then some from foreign objects on the cylinder sutface, although without a good picture of the cylinders it's hard to say.
Paul
Old 01-10-2022 | 03:04 PM
Kwikwilson007
Originally Posted by prodrag1320
torque plate & check the cylinders with a bore gauge.pistons look like they were inatalled dirty or your getting debris from somewhere else (could be the start of rod bearings going south) dosnt look like S&S stuff though,they use a 2mm oil ring and the oil rings look bigger than that.
it’s definitely s&s cylinders and pistons.. it’s stamped in the casting of the cylinders and the pistons were bought together with them from s&s .. I’m just trying to get this thing back together without major problems.. I’ve built many race car engines and hundreds of two stroke dirt bikes before. So I have the wrenching skills . It’s just the particulars of Harley engines .. the important points..
springer_
Exhaust System Topics
07-25-2023 02:56 AM
Z
Engine Mechanical Topics
31
07-30-2021 06:40 PM
Joe12RK
Shovelhead
102
05-11-2020 10:27 AM
gartec81
04-02-2016 12:01 AM
PhilM
06-06-2012 10:24 PM
Quick Reply: Replace everything it not ??
