Ring gap
Old 11-07-2020 | 09:12 PM
Andrewwayne's Avatar
Andrewwayne
Default Ring gap
Harley big bore 103 was checking ring gap and one of the top compression rings is reading .023 the service manual calls for .022 is .001 out of spec enough to worry about or just run it. The other top ring is set at .019
Old 11-08-2020 | 04:53 AM
eighteight's Avatar
eighteight
Run it
Old 11-08-2020 | 07:24 AM
Andrewwayne
That’s what I was thinking .001 isn’t that much
Old 11-08-2020 | 07:33 AM
prodrag1320's Avatar
prodrag1320
having ring gaps a couple thousands over spec will not hurt anything,having them a couple thousands under will be the problem
Ddieselsmoke (11-14-2020)
Old 11-08-2020 | 09:39 AM
bustert's Avatar
bustert
turning in acceptable numbers? if yes, run it.
if it bothers you, you may get away with just a new set, just measure everything. what i do is buy a set over and custom cut for the lowest allowable running clearance. make sure all your parts are designed to play nice with each other.
Old 11-08-2020 | 09:51 AM
Andrewwayne
Thanks for the replies, I got them on the pistons now so I’m gonna go with it probably a lot from the factory like that anyway. I know what I know and don’t mind asking when I don’t know.
Old 11-08-2020 | 11:02 AM
470004's Avatar
470004
It see no problems.
Old 11-08-2020 | 11:20 AM
Andy from Sandy's Avatar
Andy from Sandy
What are all the numbers from the manual for your engine?.
As an example my 1200 Sportster engine with new components can have a ring gap of 0.007" to 0.020". The wear limit is 0.032"
Old 11-10-2020 | 06:48 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
.004", .005" per inch of bore is the MINIMUM standard, unless otherwise specified.
Too tight and they will fracture.
Scott
dyna50
Engine Mechanical Topics
28
09-10-2023 01:06 PM
cthowards
Exhaust System Topics
03-05-2016 12:54 PM
RedJada
Classic
04-13-2014 08:06 AM
CDN. RG
11-23-2008 11:14 AM
Americanbear
10-22-2007 09:49 PM
