Help ID my Air Cleaner ('04 TC88 EFI)
There is a hint of pink on your filter element, so I'm going to guess it is a K&N. The new filter element is white, however K&N use red oil to wet the filter, which is where that colour comes from. That filter element, the oil and cleaning fluid are all available from you preferred supplier!
It's just a standard K&N replacement that was sold back in the day as the Screamin' Eagle air cleaner and is coming apart. It was available separately and in a kit. As noted above, HD moved to a different manufacturer but had same dimensions. It also looks like you have the one piece mounting studs (can't 100% see. They were problematic for breaking off at times. HD replaced them with a 2 piece unit (a bolt in a collar) but the aftermarket kept using the cheaper design.
DK Custom
Exhaust System Topics
03-31-2015 04:05 PM
