Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
if you get one for an 07 and later it should be good. i would think the main issue would be the o ring that some of the aftermarkets use, and HD doesn't on that cam plate. call fueling in the am and see what they say.
m
The anodized coating on my plate begs to differ. I’ve found some online that don’t use the plate as a backing surface.
plus when hot there was only 5-7 psi of oil pressure.
