FXDB Hillside 117”
FXDB Hillside 117”
Been absent on here for awhile, but I’m starting a new build so I figured I’d better check in. Blew the 103” for the second time, the retaining clip on the rear cylinder intake valve broke, causing the valve to drop into the cylinder. Coming into contact with the piston turned the valve stem into as S and sent debris into the front cylinder as well. After a bit of contemplating I ended up giving Hillside a call. Scott and I talked a bit about my riding style as well as horsepower & torque goals. We decided on a 110”, TMan 660ps2, Hillside’s Stage III headwork, HPI 55mm throttle body. I’ll keep the thread updated and add photos as the build progresses.
jroger24 (03-01-2020)
Yep, pretty much. Bouncing off the rev limiter in 2nd gear which is set to 6,500, bang, no more potato potato
Prodigal_Sun (01-15-2020)
