Got Engine Codes
Got Engine Codes
Ok so I followed the instruction given on here( again thanks) and this is what I came up with. The "Y" mean yes I assume as others had "N".
ECM Y
p0132
0n001439-01
BCM Y
62116
62271
SPD0 Y...not sure if the D is a D is way a funny character
u0100
Also this showed up somewhere pn41000351a
Any feedback would be greatly appreciated. Thanks.
The 'y' means there is a code stored there in its particular system. ECM code stored? Yes
BCM code stored? Yes
Speedo code stored? Yes
The code that looks like a part# -is a part# of the operating system or version the bike is running under (software version).
Start with the P0 code (google it) and go from there.
Start with the P0 code (google it) and go from there"
Which code looks like a part #. There are several codes. And what does that mean? That part might be bad? Thanks.
The one that popped up (pn4100035a) is a part number. Thats why its prefix is 'pn' (for Part Number). Its just telling you what version operating system the bike is using.
google the ECM codes you got (the one that starts with p0) and find out what that code means- then move on to the BCM codes.
