Kit stage III (29893-07B) with cnc ported heads
Hello DJL.
finally Im going to install in the 103 kit the se forged piston high compression kit (10.5:1) with the se 585 cams. Also install the ACRs .
I have a doubt with the pushrods, i can use the stock ones also right? Because in the catalog se, says use 18400-03 with cnc ported heads ( its the stock Size) i buy the highlift jhonson b2313se lifters
whats your opinion to use this cam in a dyna? It will be dificult to tune with the sept? thanks!
Now I am confused. Your original post said you purchased the 28893-07B kit and the CNC ported heads which have stock 85cc chambers. That kit comes with SE255 cams and flat top pistons. I don't know what you are doing now but do know that you should not be installing high compression 10.5:1 pistons with CNC heads and SE585 cams; compression will be too high.
so its better option the first idea right?
Thanks
No. Install the kit as it comes with the flat top pistons, .045" head gasket and the CNC ported heads along with the compression releases; you will need them. The 32109-08B tuner you have has the "smart tune" feature so you can download a baseline tune from the available options, just find the one for this kit or the one closes to it then "smart tune" from there. If you don't have the manual, you can probably find one online.
wich numbers of hp and Torque i can have with mu kit?
The highlift Johnson b2313se Will work good in the kit?
Thanks for your help
[CITA = octavo; 19253552] [CITA = MARCOS BERMUDEZ JORGE; 19253106] ¡Gracias por el consejo! Lo haré.
wich números de CV y un par i pueden tener cita]
Por favor, siga los consejos bien aquí, comprometerse con un plan y seguir adelante
usted no puede montar una hoja de banco de pruebas [/ quote]
Yes I have the kit and the heads, but i were looking if this option of the pistons 22144-08B with the SE 585 its possible. I see dyno numbers very interesting.
thanks
thanks
