Are Andrews 48H cams compatable with screaming eagle pro street tuner?
Old 07-20-2019 | 04:12 PM
79roadster's Avatar
79roadster
3rd Gear
Default Are Andrews 48H cams compatable with screaming eagle pro street tuner?
Hello I have a 2008 Softail custom with stage one Vance and Hines pipes screaming eagle intake and screaming eagle pro street tuner.
I went out out last month and bought a set of Andrews 48H cams when I was about to install them I heard that you cannot tune the screaming eagle tuner to anything besides screaming eagle cams.
Is this true or will I be able to smart tune these cams to my bike
any advice?
Old 07-20-2019 | 07:07 PM
ntraindavefl's Avatar
ntraindavefl
Maybe you should go back out and buy the Andrews tuner to be sure.
Old 07-20-2019 | 07:22 PM
79roadster's Avatar
79roadster
3rd Gear
The bike is already locked to the screaming eagle tuner that’s the problem. I woulda got a different tuner if I knew this would be the problem
Old 07-22-2019 | 06:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
any advice?
That is a complete falsehood.
Andrews 48 cams are the non-emission version of the S/E 255's.
Should be a walk in the park to tune.
Scott
porkster (10-09-2022)
Old 07-22-2019 | 08:46 AM
djl's Avatar
djl
Received 2,232 Likes on 1,614 Posts
Is this true or will I be able to smart tune these cams to my bike any advice?
Think about it; the tuner doesn't know whether the cams, pipes or intake are HD or aftermarket.
Old 07-22-2019 | 09:08 AM
Fat11Lo's Avatar
Fat11Lo
You are talking about the old "Race"(black) or "Pro"(orange) Super tuner?
The new "Street" tuner is very limited
Old 07-22-2019 | 09:23 AM
Weeboy1's Avatar
Weeboy1
Follow advice of #4 and #5 above
Old 07-22-2019 | 06:41 PM
79roadster's Avatar
79roadster
3rd Gear
The black pro street tuner
Old 07-22-2019 | 06:51 PM
IdahoHacker's Avatar
IdahoHacker
Received 2,991 Likes on 1,693 Posts
The Screamin' Eagle Pro Street Tuner has the ability to download tunes from the HD list of available tunes. 100% of these tunes are for Harley-Davidson and Screamin' Eagle parts. There are NO tunes available for non-HD parts.
Other than the standard downloadable tunes, the Pro Street Tuner has a very limited ability to make some very limited adjustments to the standard tunes. The best description of the Pro Street Tuner is that it isn't really a tuner module.
The Pro Street Tuner does NOT have the ability to effectively tune a non-EPA compliant cam.
Old 07-22-2019 | 09:19 PM
djl's Avatar
djl
I am not a tuner but from the description in the SE Performance Catalog, it would appear that the SE Pro Street Tuner does have the ability to flash tune a build with aftermarket components, i.e., cams, head, intake and exhaust via data logging and auto tune or on the dyno. I would think that since the Andrews 48 is very similar to the SE255, the SE 255 Stage whatever calibration could be loaded and Smart Tuned to a final configuration. What am I missing?
Quick Reply: Are Andrews 48H cams compatable with screaming eagle pro street tuner?
