Are Andrews 48H cams compatable with screaming eagle pro street tuner?
Old 07-23-2019 | 08:15 AM
roussfam's Avatar
roussfam
Received 7,229 Likes on 3,757 Posts
I was under the impression that some cams require timing changes, and Smart Tuning will not change timing?
Old 07-23-2019 | 08:31 AM
jbarr1's Avatar
jbarr1
IMHO, I feel that the Street Tuner is so limited that it isn’t capable of PROPERLY tuning an engine even with all SE components. It will get it a bit closer than no tune at all but it is just too limited in capabilities.
Old 07-24-2019 | 10:54 AM
Fat11Lo's Avatar
Fat11Lo
Originally Posted by 79roadster
The black pro street tuner
any way you could post a pic or part number of the VCI?
Do you have the cables? It needs to interface with a laptop to be able to use it
I think we need to figure out exactly what you have before we can make suggestions to help you
Originally Posted by djl
I am not a tuner but from the description in the SE Performance Catalog, it would appear that the SE Pro Street Tuner does have the ability to flash tune a build with aftermarket components, i.e., cams, head, intake and exhaust via data logging and auto tune or on the dyno. I would think that since the Andrews 48 is very similar to the SE255, the SE 255 Stage whatever calibration could be loaded and Smart Tuned to a final configuration. What am I missing?
That would be the way I would approach it. Load a 255 map, run smart tune sessions until I got the VE change under 5% preferably under 3%, maybe tweak the AFR a little, run some data logs and check for spark knock, make sure it's not pulling massive amounts of timing. Should end up with a halfway decent running street machine
The new version of the street tuner I thought was orange. I do remember a street tuner (I think it was black) that was available back in 2011 when I bought my Lo, but my dealer steered me away from that one because of it's limited adjustability and sold me the Pro Super tuner even though they had no idea of how to "smart tune" with it. Now I use Powervision and it's just a useless piece of plastic that I won't throw away
Old 07-24-2019 | 09:26 PM
79roadster's Avatar
79roadster
3rd Gear
So I installed the cams and tuned it to stage 2 with SE-255 and 103 big bore. then took it for a ride and recorded the data with the tuner came back and tuned it to that and it seem to run great no popping or backfiring at deceleration and has gets up and goes a lot better than stock
The following 2 users liked this post by 79roadster:
Big Dave (07-24-2019), Fat11Lo (07-26-2019)
Old 07-25-2019 | 07:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Yep.
Scott
Old 07-25-2019 | 09:30 AM
djl's Avatar
djl
Received 2,232 Likes on 1,614 Posts
Tell me it ain't so! The Andrews 48 is not an EPA compliant cam and the exhaust is aftermarket!! How is it possible with that POS SEPST? Might even be able to tighten the tune with more data logging and tweaking? Glad to hear the results and if you ever get the bike on a dyno, please post the results.
Old 07-26-2019 | 08:46 AM
Fat11Lo's Avatar
Fat11Lo
NICE, you can compare your VE tables before and after to check % of change, Usually takes a few runs to get them less than a 5% change. SE tuner isn't that hard to use just takes a little thought
e6fmf
Touring Parts
07-21-2018 04:50 PM
Rams
09-10-2017 08:51 AM
KICKSTAND1966
11-21-2015 01:27 PM
richy rich
02-04-2009 01:48 PM
2fas4u2
Exhaust System Topics
11-13-2007 08:19 AM
Quick Reply: Are Andrews 48H cams compatable with screaming eagle pro street tuner?
