SE Hurricane 120RX Heads too Much For SE 110 with SE 259E Cam??
I have a 2017 Softail Slim S and I decided to change the cams, which are the SE 259E cams. I also decided to do a head upgrade and bump the compression to 10.5:1. I left the head choice up to the dealership, and today I saw the heads for the first time and they are the SE Hurricane 120RX Heads. They look like they are waayy too much head for my 110! Has anyone else tried this combination with any success, or should I put them on the shelf for a latter day/build? Any help would be appreciated.
Yeah Steve, I'm up here in this thin air and if it will wake up at 11:1, I will have the heads milled. Any idea how much I need to take off them to get it to 11:1?
One of the main problems with HD engines are the loose tolerances. If your going to get into it, when you disassemble it check the deck height before you do any machine work. The stock 110 engine were between 9.5 and 9.9 to 1 most of the time. So if your going to swap to 10.5 pistons you need to know where they are once installed to figure real compression ratio. Many times you will find the pistons are down the bore when at TDC so you need to cut the cylinder length just to get them up to the top where they belong. Once you get there, then your 10.5:1 pistons will really give you 10.5 or very close to it. Then you need to cc the heads and see how big the chambers really are to figure how much needs to be cut. The 259E camshaft is a mid to upper RPM camshaft and it doesn't like lower compression ratio's. Then where you live, and it's just not the best combination unless you get the compression up.
TODDNVAL
11-13-2008 12:49 PM
