Crazy build... having issues, surprise surprise
OK so I have a 2008 Ultra, when I bought it It had a 120" with an S&S crank in it. ohlin's suspension, +1 oil sump, Fueling cam plate/oil pump with Tman 660 cams... she was a monster. sadly the crank seized about 1500 miles after I got it and that's when I discovered the previous owner put money into the looks but didnt like maintenance I guess. Anyways I opted to go with a Jim's 131" motor because I got a good price on it and figured go big or go home. My current build is a 131" Jim's crank with a SE cam plate and oil pump. with Tman 662 gear driven cams/S&S lifters. R&R cycle Stage V heads/forged roller rockers. I assembled the motor myself and installed it myself as well. HOWEVER i did not adjust the pushrods properly and proceeded to bend both intake valves after I tried to adjust them. Trust me my wallet and my ego are hating me right now because I discovered very quickly I did it wrong. I am now trying to hunt down valves for it. I have 2" intake valves and 1.625 exhaust valves, but the only valves I can find say max of .6" lift....am I correct in assuming these will not work with my 662 cams? or am I missing something?
thank you
thank you
