Query regarding my K&N air filter
Hey all, so I've this air filter from K&N that I found in the cupboard previously used by my brother. It looks neat and has no holes as such but only this minor zig zaggy pattern bugs me, is this normal and safe for usage? I'm yet to oil the filter, no leaks visible under light as well, regards.
Worth noticing is that, this wavy pattern exists only on 3 fins in particular, rest all seem fine.
PistonHearted (05-09-2019)
The filter is good and safe to use. Go ahead and oil it up. If you havn't oiled a K&N filter before give it a light coat of oil and let set for awhile, then reapply another light coat of oil. Repeat if necesary. What you want is a uniform coating of oil but not dripping wet, it should be a uniform color of oil with no white spots (K&N oil is red) .
Wait about a half hour. You don't need to oil the inside. Again use light coats until you have a uniform coat of oil. Several light coats are better than one or tow heavy coats.
PistonHearted (07-04-2019)
