Piston type questions?
I'm looking at the piston options for a 95" build and I'm seeing flat top and I know what they are but, then I see things like 10cc dome and 8.75 pop up. I dont know what a pop up type piston is. Is there a difference between dome and pop up? What would the advantage or disadvantage of a pop up be? Also I did a search and really could find a answer to the difference. I saw somewhere say dome and pop up were the same but, that doesn't make sense to me as looking in the same manufacture they list all 3 types.
Thanks
Thanks
That's good advice and I will be sure to do that however, now I'm still wanting to understand this pop up type of piston. I've been looking and have seen a few pictures and on most of them I can't see any type of dome or anything. The pictures I've seen look like flat top so I'm just confused now. Any one have some show and tell pictures?
I'm just trying to get a better idea why a company like s&s for example would list some pistons as dome and others as pop up if they're the same. I agree this conversation could go down the rabbit hole very quickly.
Yes I understand compression ratio. For a basic description it's the volume from bdc to tdc that is of course very basic and just a static ratio. And cams and elevation and that will figure in to the corrected ratio.
I think the term "dome" is from years gone by where the dome shape was hemispherical and the dome on the piston looked like an actual dome. Now that combustion chambers come in all types of bathtub shapes the piston is left with this funky looking plateau over the piston crown that doesn't look at all like a dome. They needed to call it something, so pop-up was used.
They generally mean the same thing as far as increasing compression goes. The difference is a dome will be thicker on the top so it can be machined to adjust to the desired compression whereas a pop up will have the same shape on the underside of the piston & can't be machined.
